More CC2017 weirdness. Does not like scroll bars
Duke Sweden
on Nov 18, 2016 at 3:25:54 am
For some reason, and obviously this is only happening on my computer because no one else has complained about it, but CC2017 seems to be averse to creating scroll bars. I can only access assets (access assets, access assets, access assets!!) in the project panel by switching to list view. And in the Program Monitor if I change the size from "Fit" to 75% or whatever, there are no scroll bars to move the video around.
Just adding to the pile.
Tero Ahlfors
Re: More CC2017 weirdness. Does not like scroll bars
on Nov 18, 2016 at 6:02:58 am
Do you have a screenshot? There will be no scroll bars if everything fits in a panel. Also if you have multiple monitors make sure that the Premiere window isn't going over to the next one. There's some UI weirdness in CC 2015 if the window is creeping over to the other monitor.
Duke Sweden
on Nov 18, 2016 at 10:02:18 pm
Yeah, I know all about that. Even one pixel over to the second monitor wacks things out. No, that wasn't the problem, and, as I said, when I went from "Fit" to "100%" the video was much larger than the window but no scroll bars. HOWEVER....today there are scroll bars. Go figure.
Ann Bens
on Nov 18, 2016 at 10:27:39 pm
I have seen this: resize the panel manually or reset to saved layout.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Duke Sweden
on Nov 18, 2016 at 10:54:19 pm
I have the panels going from top to bottom of my screen on my second monitor so I can only resize them smaller. Never had a problem before but, as I said, today the scrollbars are appearing, even in my program monitor.
Scott Bush
on Dec 2, 2016 at 3:34:18 pm
Wanted to say this happens to me too. Resizing the window just a tiny bit makes them appear, but especially in the project window the scroll bars do not always draw even when they should. They simply aren't there until I resize the window as mentioned before.
For reference I'm on a Mac Pro 2013 (Trash can) with Dual D500 GPUs and a dual display setup (2 1920x1200 displays, connected via thundebolt-DVI adapters).
Duke Sweden
on Dec 2, 2016 at 3:39:38 pm
So I'm NOT crazy!!! Told ya, Dave LaRonde!
Anyway, like I said, they now appear regularly and on schedule.
