Unrecognised audio by Premiere Pro
Mike Kann
on Nov 17, 2016 at 6:44:12 am
Weird Problem
I have just recorded my screen as an MP4 with an MPEG4 codec, playing the video back all works fine: the video is goo, computer audio good, computer mic good. It plays back fine in every video player but as soon as I put it in Premiere Pro CC 2015.3 it says the clip has no audio.
Similarly trying to open it in Adobe Audition it says it is a clip with no audio.
I opened the clip in PluralEyes and that played with audio but then when I export it into an FCP format for PP, opening this in premiere takes the footage offline then when re-linking says it has no audio.
Converting the files in Media Encoder has not had any success, nor has re-recording the footage with H.264 codecs. Previous versions of PP have the same problem.
I have tried lots of solutions from threads that are similar but nothing seems to be quite the same as this.
Any Ideas from anyone?
Cheers
Daniel Waldron
Re: Unrecognised audio by Premiere Pro
on Nov 17, 2016 at 2:02:50 pm
How long is the clip?
Ann Bens
on Nov 17, 2016 at 2:50:49 pm
Convert with Handbrake and also set it to constant framerate and try again.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Mike Kann
on Nov 17, 2016 at 9:14:15 pm
Fixed! Thank you very much Ann Bens.
Using Handbrake to convert it to a constant frame rate has fixed the problem.
