"Gang to Program Monitor" from Reference Monitor
Darren Lee
on Nov 15, 2016 at 6:47:17 pm
I'm trying to get the Reference Monitor to play exactly what is in the Program Monitor, with Gang to Program Monitor selected, but it only updates when the playhead stops, not as it's playing.
Is there an option for this?
Using 2014.2
Jon Doughtie
Re: "Gang to Program Monitor" from Reference Monitor
on Nov 15, 2016 at 7:54:31 pm
To the best of my knowledge, that is normal behavior for the ref monitor in that release.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Peter Garaway
on Nov 15, 2016 at 7:59:25 pm
Hi Darren,
The Reference Monitor does not playback simultaneously with the Program Monitor. Any reason why you want it to? If you're looking for another way to watch your timeline, you could use a secondary monitor via Transmit.
Peter Garaway
Adobe
Premiere Pro
Darren Lee
on Nov 15, 2016 at 10:23:30 pm
Hi Peter, thanks for replying
I want to use two Program Windows; one with a Multi-Camera view and the other with Composite Video
When you say use a secondary monitor via Transmit, do you mean literally plug in another physical monitor? Or is there an effective way of doing using Transmit?
Peter Garaway
on Nov 17, 2016 at 6:36:02 am
Hi Darren,
Yes, sorry for not being clear. I did mean to 'literally plugin' a second monitor. Otherwise I don't think what you're trying to accomplish can be done.
Peter Garaway
Adobe
Premiere Pro
Darren Lee
on Nov 17, 2016 at 8:31:35 am
Ok Thanks Peter,
I've checked "Show Multi-Camera Preview monitor", which aligns a window to the left, as that's almost what I'm after.
Is there a way to rearrange the Multi-Camera Preview monitor so that it is stacked vertically, or detach it in some way?
Thanks again
