Setting up Audio in Premiere
Scott O'Hara
on Oct 29, 2016 at 12:09:12 am
Hey All,
Been editing for quite a while, but still having trouble pinning down the best setup for audio mapping/panning and exporting.
Particular example below.
Getting Mono Source files. 3 people mic'd total of 6 mono channels.
Channel 1: Mix L
Channel 2: Mix R
Channel 3: Boom
Channel 4: Lav 1
Channel 5: Lav 2
Channel 6: Lav 3
I'm creating a multi-channel sequence with Standard tracks with the eventual output to stereo with option of discrete channel exports if need be (from multichannel).
My questions are:
-Right now, the boom and lavs are center panned. When done with the edit I create a stereo submix and direct the tracks through that to get stereo. Or I cut and paste the multichannel sequence into a stereo sequence.
-BUT! I thought I remember a sound mixer telling me they should be panned left (the mono tracks at first). Then when going to a stereo export you fill the right channel to get true stereo. But I totally forgot what he told me as it was years ago. But I thought center panning mono tracks will give you a muddied sound.
-What's the CORRECT way to set this up in Premiere for multichannel sequences, then getting stereo out of that with true L and R panning for the cleanest sound?
Any help would be greatly appreciated.
