Canon c500 and Odyssey 7Q+ Workflow with Premiere Pro CC
Isaiah Illingworth
on Oct 25, 2016 at 10:12:40 pm
Hey everyone,
I'm editing a piece that was shot on the Canon c500 in 2k 12 bit Uncompressed. The files are ProRes 4444XQ and were recorded with the Odyssey 7Q+. The issue I'm having is that I have a bunch of split clips from the recorder and I'm having trouble merging them properly in Premiere. I can't merge or create subclips with more than one clip and an audio track. It still doesn't work when I nest the split clips.
Anyone have any recommendations for how to best sync all my files with this file structure?
Jon Doughtie
Re: Canon c500 and Odyssey 7Q+ Workflow with Premiere Pro CC
on Oct 26, 2016 at 3:47:43 pm
Isaiah, how are you bringing your footage into the project?
If you are using the Windows dialog to import (CTRL+I or CMD+I) try using the Premiere Pro Media Browser instead.
In many instances, Media Browser will detect spanned clips, and automatically import them "stitched together" for you.
If you are already using Media Browser, well, I'm a little stumped.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Isaiah Illingworth
on Oct 27, 2016 at 7:29:42 pm
Thanks for reaching out Jon. I found a workaround with some Convergent Design Software called ProRes Transfer Tool. It just stitches clips together. I wasn't having any luck with Media Browser.
Best
Isaiah
