Premiere pro render problem
Anais Cappe
on Oct 25, 2016 at 1:52:44 pm
Hi there, I have a rendering problem on premiere and I wanted to know if someone could help me with it.
Basically, I can't render a video editing on premiere that I made for a short movie. Everytimes I try to, it gets stuck while looking for the audio previews of the songs of my project, even before the real render starts.
Well, these songs are probably causing the problem but I can't just delete them.
To give you some information, some of them are wav files and others mp3 (24/32 bits, 44kHz, stereo). Plus, I added few different effects on each like EQ, reverb or lowpass.
Maybe it's because of all those effects that I added..But here again, I would like to avoid deleting any stuffs and find another solution if it's possible.
So did some of you encounter the same problem and found a solution other than just delete the whole thing? If yes, please tell me because I don't really know what to do.
By the way, I'm using the last update of premiere pro (premiere pro CC 2015.4). My video footages where taken from a Canon 5D (.mov, 1920x1080, 25 i/s). And my render settings are H.264, audio AAC, 48 kHZ, stereo.
I tried using both premiere pro itself and media encoder to render my project but I get the same problem on both. Tell me if you need more information.
Thank you !
Jeff Pulera
Re: Premiere pro render problem
on Oct 25, 2016 at 4:06:15 pm
I've seen others say that MP3 files can be an issue for Premiere, might help to first convert them to .wav 48k to match video project. Could use Audition if you have it.
Jeff Pulera
Safe Harbor Computers
