Audio glitches when exporting master file
Ludmil Kazakov
on Oct 23, 2016 at 10:07:59 pm
When exporting the master file with sound there are areas where audio pieces get looped.. when i refer back to the project there is not even an audio file there.. . even when i export just a WAV of the audio the issue is still there.. In an hour and 45 minute feature this happens 4-5 times.. this is unacceptable and very frustrating..
I am on the original Premiere Pro 2015CC version, little nervous about updating in the middle of the project.. i tried cutting out the looped audio from the wav export and re-exporting in the newest version Premiere and it worked fine..
Anything I can do to make this go away? clean cache?
Dave LaRonde
Re: Audio glitches when exporting master file
on Oct 24, 2016 at 2:20:16 pm
Don't use mp3 audio. It is unreliable. Use Audition to convert it to wav audio.
Clearing the caches is always a good thing before a big export.
Dave LaRonde
Promotion Producer
Ludmil Kazakov
on Oct 24, 2016 at 2:29:04 pm
my idea is to have it done right first time and not to have to export it twice, once for sound once for picture.. at this stage its not a master but needs to be watched by producers without glitches in the audio.. my export setting is vimeo720p in media encoder..
Dave LaRonde
on Oct 24, 2016 at 2:51:44 pm
You didn't mention anything about mp3 audio, which is my point. It can cause problems. Problems such as the ones you face. So I repeat: if there is mp3 audio in your project, you do yourself no favors by keeping it there. Replace it.
Dave LaRonde
Promotion Producer
Ludmil Kazakov
on Oct 25, 2016 at 12:43:09 am
yes but in my case its MXF video and audio.. the mp3 music around it was converted to wav.. so thats weird.. it happens on clean audio with no score under it
Tero Ahlfors
on Oct 25, 2016 at 9:47:44 am
[Ludmil Kazakov] "clean cache?"
Might help?
Ludmil Kazakov
on Oct 30, 2016 at 4:10:55 am
yes.. cleaned it.. found the problem.. there is a glitch with older version premiere where it generates a loop certain audio
