Batch Exporting with In & Out Points
Paul Factora
on Oct 17, 2016 at 10:50:59 pm
It's gotta be a simple solution but I'm missing it.
I'm batch exporting a dozen clips with separte in & out points from the same master clip.
Media Encoder will then export the full clips and not go by the in & out points.
How do I ensure the export will contain only the part of the clip that I've set In & Out points to?
-p
Tero Ahlfors
Re: Batch Exporting with In & Out Points
on Oct 18, 2016 at 3:55:02 am
[Paul Factora] "How do I ensure the export will contain only the part of the clip that I've set In & Out points to?"
If you're doing this in the source window you'll need to make sure you select the in/out range manually. It will default to the whole clip. There's a drop down menu below the preview screen in the export window.
Alternatively you could make subclips from the source clip and batch export them.
