Generating an audio waveform for video
Andrew Iden
on Oct 17, 2016 at 3:29:29 pm
All-
Longtime reader of the forum, but this is my first post, and after alot of digging, i'm looking for some help. I want to use an audio file and generate an audio spectrum/waveform for the audio (it's a 911 call) in the same way that this video executed it. I've looked high and low on Final Cut as well as Adobe Premiere, and haven't yet seen the proper method. It's entirely possible that I've overlooked the right path to executing this look, but I thought you folks here might be able to point me in the right direction. Thanks so much for anyone who might have the silver bullet!
Andrew Iden
Alan Lloyd
Re: Generating an audio waveform for video
on Oct 17, 2016 at 5:05:53 pm
This is an After Effects solution from 2011. Maybe it will help?
https://www.macprovideo.com/hub/after-effects/generating-visual-audio-wavef...
Peter Garaway
on Oct 17, 2016 at 6:19:18 pm
Hi Andrew,
Your link did not work for me, but I think I get what you're saying. Alan is pointing you in the right direction. After Effects is the place to get the job done.
Here's a few different tutorials that provide some cool things you can do with the Audio Spectrum effect.
Best,
Peter Garaway
Adobe
Premiere Pro
