Problem in Premiere
Von Thomas
Problem in Premiere
on Oct 16, 2016 at 5:23:10 am
I have a weird issue, I’m exporting a XML roundtrip into Premiere from Davinci, and the color is not going as it should. Here is an exported screenshot of the exported look
Here is the imported look inside Premiere
When I import into Premiere I get this error message
Can you tell me what I’m going wrong? If I import the XML back into Davinci, it looks good, but not in Premiere.
Von Thomas
DIT / On-Set Dailies Colorist
Massimo Alberto Croce
Re: Problem in Premiere
on Oct 16, 2016 at 10:27:01 pm
It seems you have some effects applyed from the translation from xml from resolve. Look at the clip effect editor, and see if any effect is applyed
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Von Thomas
on Oct 17, 2016 at 5:33:40 am
It seems that PP is putting a color correction on top of my color corrected timeline. Now trying to see how to disable the Lumetri color for the entire timeline. Thanks Warren Eagle for the info.
Von
Von Thomas
Tero Ahlfors
on Oct 17, 2016 at 9:27:20 am
Are you replacing clips on an excisting timeline? If the corrections are per clip you can select all of them in the timeline and right click - remove attributes.
