Trouble keying around hair
Michael Rose
on Oct 13, 2016 at 4:10:30 pm
I've had no luck getting a good key around a subject with stringy hair. Admittedly, our lighting and setup wasn't as good as it could have been, but I'm wondering if anyone has any tips? I've tried different keying approaches in Final Cut and AE with no luck. I'm not particularly experienced with either program, so I very well could be missing some tactics.
I've uploaded a portion of the original video file for review.
Ann Bens
Re: Trouble keying around hair
on Oct 14, 2016 at 12:14:58 am
I would use Ultra Key and use the green next on the left to the hair.
I would do a second key just on the body/arms (on a separate layer)
Nest the both then a mask from opacity for the rest.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Michael Rose
on Oct 18, 2016 at 4:41:24 pm
Hi Ann,
I apologize...I'm novice when it comes to Premiere Pro. Would it be possible for you to explain this process in a bit more detail? I'm not entirely sure of the workflow. Thanks!
Remus Hosu
on Jul 16, 2017 at 7:01:15 pm
Check out this tutorial on Ultrakey:
https://bluefx.net/green-screen-keying-ultrakey-adobe-premiere-pro/
Hope this helps out
http://bluefx.net
