Copy from the source monitor to After Effects?
David Cabestany
on Oct 10, 2016 at 3:32:36 pm
Hello all,
Is there a way to copy from the source monitor with in and out points already set directly to After Effects?
D.
Peter Garaway
Re: Copy from the source monitor to After Effects?
on Oct 10, 2016 at 6:17:33 pm
Hi David -
I believe it has to be in a sequence in order for the in and out point data to come through. You can create a sequence with the in and out points set and just copy and paste it over or of course right click in the timeline > Create a new After Effects comp from clip.
Best,
Peter Garaway
Adobe
Premiere Pro
David Cabestany
on Oct 12, 2016 at 7:48:31 pm
Thanks Peter. I ended up doing that. Not that I am THAT lazy, but I had to do it about a hundred times, so any step I could have saved was welcome.
Thanks a lot for replying.
Tero Ahlfors
on Oct 12, 2016 at 7:55:43 pm
Edit your 100 clips to a sequence, copy and paste from there.
