Premier pro cc messes up certain clips...
Jimmy Parasyris
on Oct 10, 2016 at 12:24:17 am
I am new in video so I'm experiencing a problem. I shoot with a Sony A6300 4K at 24 frames. The clips play good on camera and on computer. When I edit on premier pro cc these flickering things appear.
Fast forward to 20sec.
Thank you
Joe Barta IV
Re: Premier pro cc messes up certain clips...
on Oct 11, 2016 at 4:47:05 pm
It looks like a rendering issue. Try turning off Maximum Bit Depth and Maximum Render Quality in the Sequence Settings.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
Jimmy Parasyris
on Oct 11, 2016 at 8:56:08 pm
You mean in the export box I should'nt checkmark those 2 options?
or is there something in the menu?
Thank you
Joe Barta IV
on Oct 12, 2016 at 11:41:15 am
Top menus; Sequence, Sequence Settings also has these options to check and uncheck.
Joe
Jeff Pulera
on Oct 12, 2016 at 2:00:54 pm
Rule of Thumb - the defaults are the defaults for a reason. Go with them for starters. As you become an expert with Premiere, then start experimenting. But understand what exactly those buttons do before just checking them
Jeff
