Zoom Keyframes Continued Through Multiple Clips in Premiere CS6
Steve Huang
on Oct 8, 2016 at 10:12:22 am
I'm doing a time-lapse with an image sequence as one long clip.
This long clip is cut into 3 clips, A - B - C with cross dissolve transitions between.
I would like to do a zoom out using keyframes starting at frame 1 of A at 100%
The zoom should go to the end of clip C to 75%
I tried nesting to no avail. I've hacked a solution by exporting then applying the keyframe zoom to the exported clip... very kludgy.
Any suggestions on working with the original A-B-C clips?
Thanks in advance (and I hope I made myself understandable)
Ann Bens
Re: Zoom Keyframes Continued Through Multiple Clips in Premiere CS6
on Oct 8, 2016 at 4:09:40 pm
Use the transform effect on an adjustment layer
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Steve Huang
on Oct 9, 2016 at 6:10:06 am
Thank you for your response, Ann.
Unfortunately, it didn't work because I neglected to mention that my original clip is 6k while my sequence is 4k meaning I have unseen parts of the image beyond the 4k boundaries I can work with.
The transform solution you suggested leads to black borders at 75% SCALE of original:
This does not expose the full 6k worth of clip available.
Whereas the solution I'd like is the unseen area of original clip exposed (here at 75% ZOOM):
For context and hopefully for clarity, here is a screenshot of the 4k sequence at normal 100% (excess 6k part of clip extending beyond 4k sequence border is unseen):
This is the sequence I'd like to keyframe zoom from 100% to 75% (while always filling the 4k frame) which would be easy if there were no cross dissolve transition.
Hopefully the screenshots have clarified things a bit.
