muting audio AND video with one click
Marc Nibor
on Oct 7, 2016 at 12:05:58 pm
Is there an option in Premiere that lets me mute audio and video at the same time? so that all linked audio or video gets muted when either one of them is turned off.
for example I have a videotrack 1 and all it's audio is in audiotrack 1. If I now turn off videotrack one I want it's audio on audiotrack 1 muted. Is this - or something similar possible?
similar to that what "enable" does.
Peter Garaway
Re: muting audio AND video with one click
on Oct 7, 2016 at 6:16:08 pm
Hi Marc,
No single click. The easiest way to do it would probably be to Alt/Option click on either the video or audio portion of the clip to make a independent selection and use the keyboard shortcut Shift+Cmd/Ctr + E to Enable/Disable the clip.
Hope that helps!
Best,
Peter Garaway
Adobe
Premiere Pro
dorland riz
on Feb 21, 2018 at 2:35:41 am
command shift E. Enable/Disable clip. THANKS, works for me!
( I came here looking for the same thing, a quick way to mute a clip like in Cubase, you hit the 7 for the mute tool, then click on a clip) This will do just fine. thx
doland ruiz
on Feb 21, 2018 at 2:40:12 am
oh, also that "option click to make an temporary independent selection". Nice tip, thanks!
