Exporting audio only as mp4 issue
Dougie Campbell
on Oct 6, 2016 at 1:57:23 pm
I have a client who has exported the audio only from an mp4 for me to clean up in audition. After cleaning up the audio, when I go to save it, I'm offered mp3 or wav etc as options but not mp4 so I saved as wav.
When I try to import back into PP it says The file cannot be opened because of a header error.
Any thoughts? It has been suggested I just rename the original mp4 as an mp3 but my only concern about that is that the cleaned up audio won't then sync to the original video. Am I wrong to be concerned about that?
P.S. the file he supplied is 6.5gb which seems huge for audio only. I'd like to export it back as a smaller size but, again, I'm concerned about the audio ending up out of sync with the original video file.
Any thoughts would be very much welcome.
Dave LaRonde
Re: Exporting audio only as mp4 issue
on Oct 6, 2016 at 10:00:37 pm
A wav file should be lossless. Re-import the wav into Audition, export again, and see if it's fixed.
Dave LaRonde
Promotion Producer
Dougie Campbell
on Oct 9, 2016 at 6:39:52 pm
Still the same sadly.
ryan kelly
on Nov 29, 2016 at 7:02:37 pm
I also had this problem recently. I believe it's because wav files aren't natively supposed to be larger than 4GB. The larger file sizes are allowed due to a workaround. However, I've been unable to import these into PP. I ended up breaking the file into shorter durations in Audition and stitching them back together - a process that seems unnecessary in this day and age.
