Fixing distortion from using a very wide angle lens?
Eric Pas
on Oct 5, 2016 at 4:13:48 pm
Hello!
I shot a video using a 14mm lens. The subjects were on the left and right side of the frame. Because of this and the lens, they look a little distorted and weird.
Are there any suggestions on how to fix this or make it look a little better in editing with Premiere CC? I used a Canon 5D for filming.
Jeff Pulera
Re: Fixing distortion from using a very wide angle lens?
on Oct 5, 2016 at 5:25:50 pm
Hi Eric,
Try the Lens Distortion effect
Jeff Pulera
Safe Harbor Computers
Eric Pas
on Oct 5, 2016 at 5:29:09 pm
I tried that I think but I want to say it's mainly for Go pro cameras? I can try to mess with it again though.
Dave LaRonde
on Oct 5, 2016 at 5:34:28 pm
If the lens distortion effect doesn't help, you may have to re-shoot.
Sometimes what seemed like a good idea at the time turns out to be less than a good idea. Hey, it happens.
It's also a good argument for doing test shots on ideas that push the envelope.
Dave LaRonde
Promotion Producer
Jeff Pulera
on Oct 5, 2016 at 5:46:24 pm
You may have found the Presets for Lens Distortion Removal, which are mainly GoPro and related.
If you just choose the Lens Distortion effect itself and play with the controls, you may find that it does what you want. However, you may need to crop the image a bit after un-warping it, and if your subjects are too close to the edge...
Thankis
Jeff Pulera
Eric Pas
on Oct 10, 2016 at 8:21:13 pm
Thanks for the help guys! I will try my best to mess with that Lens Correction setting.
