Stereoscopic VR sequences
Jeff Hillegass
on Sep 29, 2016 at 8:02:53 pm
I would like to create a stereoscopic VR sequence. My source is a .dpx image sequence. I have imported it once with "left eye" frames chosen first, and again with "right eye" chosen first. Is this the correct protocol for import of .dpx image sequences for eventual stereoscopic VR output?
For a top/bottom sequence, how should my sequence be setup? As a manually created top/bottom split? If so, should there be black bars at the sides (preserving all the image real estate), or should the images be cropped? If the images are cropped, should they be cropped from the top, from the bottom, or equally from the top and the bottom?
Should there be any space between the split screen images, or should they touch?
