Source Settings not appearing in “Effect Controls” panel
Leo Patrick Ahrens
on Sep 28, 2016 at 3:11:28 am
PROGRAM:
Premiere Pro CC (2015.3)
Last update: Sept 27, 2016
SETUP:
1080 timeline / RED EPIC footage / .R3D files.
ISSUE:
I am working with .R3D that I would like to change the white balance on a “Source Settings” level. If I click on the clip in the timeline then go to “Clip > Source Settings…” I’m presented the “RED R3D Source Settings” panel. That all works fine.
However, I was watching a youtube clip where the guy would edit the source settings from the “Effects Controls” panel under the “Master Clip” tab. When I look for this option I can no find it.
Skip to 26:10
How can I access the source settings in this approach?
Thank you!
Leo
Alex Udell
Re: Source Settings not appearing in “Effect Controls” panel
on Sep 28, 2016 at 2:19:47 pm
Master Clips are access by dragging a clip from the project panel into the source viewer...
then going to FX controls....
this is commonly referred to as source side effects...
they are applied prior to timeline use and the properties are not available when selecting the clip in the sequence...
so doing a base color set up is a good example of a master clip effect...then the effect will be applied in every instance of the clip usage in sequences. if the master is changed...all usages of the clip will reflect the change globally in the project.
does that help?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
