Premiere CC 15.3 -- 4K files with proxies playback issue
Kieran Mulroy
on Sep 27, 2016 at 5:24:51 pm
Hi all,
I'm trying to edit 4k files in a 1080 sequence using proxies, however when I scale the footage to a percentage when there is black showing (less than 50 percent), it gets all stuttery during playback and jumps up in size. When its zoomed in above 50%, it doesn't happen. When it's paused, or when I unattach the proxies, everything works fine. It also works when I use "Scale to Frame Size," but I don't want to use that because it lowers the 4K quality. Has anyone encounted this before? Any solutions?
Kieran
Alex Udell
Re: Premiere CC 15.3 -- 4K files with proxies playback issue
on Sep 27, 2016 at 7:35:18 pm
Maybe this thread will help
https://forums.creativecow.net/thread/3/990345#990345
HTH,
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Kieran Mulroy
on Sep 27, 2016 at 7:44:20 pm
Hey Alex,
Yes, that's exactly my same issue! The problem is that the fix they arrive at (scaling the footage to 51%) doesn't work for me because I have to have some of the clips below 50% scale to fit into screens and such. Do you know why the proxies do this? Is there another workaround?
Alex Udell
on Sep 27, 2016 at 8:04:57 pm
No....I don't know what causes it. Surely a bug.
What resolution are your proxies?
Alex Udell
Kieran Mulroy
on Sep 27, 2016 at 8:05:55 pm
I tried multiple -- first 2K, then 1080, then 540, all the same result
Alex Udell
on Sep 27, 2016 at 8:53:50 pm
So when you take 4k....
and make a 1080 out of it...
that's Pix Aspect and dot Res match your actual sequence....it's choppy?
Alex Udell
