Title creation window too small
Luís Jervell
on Sep 27, 2016 at 2:28:32 pm
When I try to create a new title the creation window is to small. What can I do to size it bigger?
I use Premiere Pro CC vs 7.2.2 (33) on a Mac MacBook Pro Retina OS X El Capitan 10.11.6 and on the timeline there is a .mp4 video.
Tero Ahlfors
Re: Title creation window too small
on Sep 27, 2016 at 3:19:17 pm
Grab an edge of the window and make it larger. Like you would do for a Finder window.
Luís Jervell
on Sep 27, 2016 at 6:07:56 pm
That doesn't work, I cannot grab the corners. I'm talking about the black rectangle inside the gray area of the Title designer panel (image enclosed)
Dave LaRonde
on Sep 27, 2016 at 6:13:38 pm
You can't. You're looking at the entire video raster. That's as big as it's going to get. You would have to make a change in the sequence settings, and I doubt you want to do that.
You might be able to un-dock that particular pane and make it larger.
Or it might be a bug in the application. There are plenty of them.
Dave LaRonde
Promotion Producer
Tero Ahlfors
on Sep 27, 2016 at 6:48:36 pm
What is the resolution of your title? If you're using a standard resolution then the view should scale to fit. I tried with some weird small non standard resolution and it doesn't do that.
Luís Jervell
on Sep 27, 2016 at 11:08:15 pm
I think that is the key to the problem, I changed the resolution to 500x400 and the black rectangle became bigger, then I went to the effect controls and brought the scale to 71 and think it solved my problem.
