best workflow for duplicated sequences with different text on each?
Mary Garito
on Sep 20, 2016 at 2:34:18 pm
I am new to Premiere (usually work in Avid) and I have a project of 100 commercials that are identical except for text. Each one has a different lower third with differing information. So I made a subsequence (to use as a template) with three layers of video: on the bottom is a graphic - the bar where the text will lay, then there is another layer with a logo, and the top layer has a title with text that will be slightly different for each spot.
I know that if I change the subsequence in one spot it will change on all the sequences/spots. So I am wondering if anyone has a good idea of the most efficient workflow for this situation.
Thank you!
