Changing length of DISSOLVE
David Smooth
on Sep 13, 2016 at 11:52:22 pm
Is there a way to change the default fade length of a dissolve?
I have say 20 clips that need a 1 sec dissolve between them rather than the standard 5 seconds and would rather not have to individually change each fade's length manually.
Cheers in advance,
-Dave
Duke Sweden
Re: Changing length of DISSOLVE
on Sep 14, 2016 at 7:00:46 pm
Yes, under edit>preferences>general you can change the Video Transition Default Duration. You can also set it for audio as well. In seconds as well as frames (i.e. 1 second or 24 frames)
