Latest update - audio track mixer bug?
David Fleury
on Sep 9, 2016 at 8:13:04 pm
Anyone else having issues with the audio track mixer not working on the fly anymore? I will be riding levels and then stop the timeline and the audio track will jump back to where it was before I started adjusting.
If I adjust while the playhead is still it will work fine.
Dave
John Pale
Re: Latest update - audio track mixer bug?
on Sep 9, 2016 at 10:30:46 pm
Sounds like you might have the faders set in Touch mode?
Off Ignores the track’s stored settings during playback. Off allows real-time use of Audio Mixer controls without interference from stored automation settings.
Read-Reads the track’s automation settings and uses them to control the track during playback. If a track has no settings, adjusting a track option (such as volume) affects the entire track uniformly. If you adjust an option for a track that’s set to Read automation, the option assumes its former value (before the current automated changes were recorded) when you stop adjusting it. The rate of return is determined by the Automatch Time preference.
Write-Records adjustments you make to any automatable track settings that are not set to Safe During Write, and creates corresponding track keyframes in the Timeline panel. Write mode writes automation as soon as playback starts without waiting for a setting to change. You can modify this behavior by choosing the Switch To Touch After Write command from the Audio Mixer menu. After playback stops or a playback loop cycle completes, the Switch To Touch After Write command switches all Write mode tracks to Touch mode.
Latch-Identical to Write, except that automation does not start until you begin adjusting a property. The initial property settings are from the previous adjustment.
Touch-Identical to Write, except that automation does not start until you begin adjusting a property. When you stop adjusting a property, its option settings return to their previous state before the current automated changes were recorded. The rate of return is determined by the Automatch Time audio preference.
