Premiere Pro CC 2015.3 Transition Glitches (Green)
blaize warden
on Sep 6, 2016 at 3:59:04 am
I've been attempting to add transitions to several clips in my Premiere Pro sequence but I've run into problems with 4 random clips.
Most transitions have worked, but I am having problems at 4 specific points.
As you can see in the video I've attached, I am getting a weird green glitch error.
Some of the clips are after effects sequences, others are standard footage.
I've tried replacing the footage, nothing works.
Note: I have an adjustment layer with Trapcode Looks.
Check item description for timecode:
Joe Barta IV
Re: Premiere Pro CC 2015.3 Transition Glitches (Green)
on Sep 6, 2016 at 1:13:53 pm
In the Project Settings, try switching the Video Rendering and Playback between GPU Acceleration and Software Only. See if that makes any difference.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
blaize warden
on Sep 7, 2016 at 9:12:55 am
Nope,
I only have the option of "Mercury Playback Engine Software" under video rendering and playback.
So I can't make any changes to the unfortunately.
