Can I save an output file path in my custom Export settings?
Don Ortega
on Aug 30, 2016 at 8:10:24 pm
I'm looking to set up Premiere so that it exports to a specific folder depending on which custom output setting is selected. I can then deploy that setting to the computers on our SAN and then get the right file in the right folder more often :)
Alex Udell
Re: Can I save an output file path in my custom Export settings?
on Aug 30, 2016 at 9:18:56 pm
Hi...
Instead of doing it in Premiere...
do it in Adobe Media Encoder with a setting paired with a watch folder...
Watch folders can be set to output to a destination...
Now here's the trick...
The Project Panel in PPro needs to be set up to that the sequence to be encoded in in the root of the Project Panel...
and all other items are inside at least one level of bin....
So you can then take the PPro Project file and drop it in a watch folder...
it will then encode and output to whatever destination folder you specify...
That make sense?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Don Ortega
on Sep 1, 2016 at 5:05:26 pm
Thanks for the ideas Alex and Dave!
