Quickly numbering each clip in a sequence?
Sam Carey
on Aug 29, 2016 at 4:43:30 pm
I need to number each individual clip on my timeline (so that someone else with can weigh in on the clip selection). Last time I did this, it was a very manual and long process of creating a separate text layer for each number / clip. Is there a more automatic / faster way to achieve this? Any suggestions would be very appreciated! Thanks!
-Sam
pedro paramo
Re: Quickly numbering each clip in a sequence?
on Aug 29, 2016 at 5:41:40 pm
i don't really know how to do that
Massimo Alberto Croce
on Aug 29, 2016 at 5:48:07 pm
If you have your clips mane numbered in the way you want, than you can use a "clip name " effect (you can find it under effects>video) and apply to the clips direr or on a adjustment layer (in this case remember to change the source track from none to the track where the clip exists)
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Alex Udell
on Aug 29, 2016 at 8:20:17 pm
Why not export a proxy with time code overlayed?
then they can refer to the point in time where they want to change...
you can do this via export and enable in the effects tab.
no mods of your timeline or media necessary....
or if you are exporting a references of all you sources....they can still identify it by the timecode and you can match frame from your time line or reveal in project quickly access the shot....
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
