FCPX User Trying to Understand How to Lengthen a Clip
Wesley Kelemen
on Aug 23, 2016 at 9:02:36 pm
OK so I like FCPX but sometimes the client demands Premiere. In FCPX the timeline adjust itself so If I need an extra 2 seconds I just pull it and it will push the other clips. In Premiere well it doesn't budge...Whats up with that?
Also lets say I end up with a black space in the middle of a complex edit with 3 lines of audio, titles etc. I try to drag and select everything I need to move. So I'm selecting alot of clips. So in premiere you gotta click on the tiny little text if you want to move the selection but don't hit the side or the opacity. Thats not easy but anyways when I go to move this huge selection the clips don't snap anymore. I pressed "s" it's not that. It's only when I have a lot to move it doesn't snap.
I cannot figure out a way to move the selection because without it snapping it can't be prescise.
Thanks guys
Alex Udell
Re: FCPX User Trying to Understand How to Lengthen a Clip
on Aug 23, 2016 at 9:26:10 pm
Hey there...
To drag out.... you should use the ripple tool....
also editing in the seq can be drivenby keyboard once the trip point(s) is/are selected
U will cycle thru the modes (orange equals rippling....red equals rolling)
< > with trim -/+ 1 frame
<> + SHIFT -/+ 5 frames
\ will play around edit
up down will jump between edit points on selected trax....
Snap toggle is N as in "sNap" by default. :)
you can also nudge with
option + arrows (1 frame)
option + shift + arrow ( 5 frames )
cheers...
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
