Is there a way to adjust offset sync in an existing merge clip
Gunleik Groven
on Aug 19, 2016 at 3:09:32 pm
Here is what I wanna do:
I have a merge-clip that comes in pre-formatted with metadata, TC sync and scene/slate/date info, but for whatever reason the TC doesn't match 100%
I can pull it into a sequence, unlink and re-sync, but that is not reflected in the master (original) merge-clip.
I would like to have the same option as with multi clip where I can manually refine the sync on clapper if necessary, without breaking the file and metadata relations in the "master" merge-clip.
Gunleik
http://gamp.io
