Generating Peak Premiere Pro CC
Debora Cavalcante
on Aug 17, 2016 at 8:40:17 pm
Hello, Creative Cow personnel.
I am Brazilian and I work with editing, and I'm with these doubts and I want you to help me solve.
I need to know a way to Premiere Pro CC not generate peak files when importing videos to the software as they take up much space when working with large projects that are heavy'm using also the final cut 7.3, but want to migrate to use only Premiere Pro CC. What should I do?
Is there a way or not to prevent them from being generated?
Thank you!
jerry wise
Re: Generating Peak Premiere Pro CC
on Aug 17, 2016 at 10:27:37 pm
i think it's in Preferences/Audio/Automatic Peak File Generation.
Jon Doughtie
on Aug 18, 2016 at 3:32:34 pm
PPro is going to generate those PEK files. There is no way to stop it from doing so that I am aware of.
When it is time to archive your project, you can delete them. If you open the project again it will re-generate them as needed.
If the issue is they are devouring space on your system drive, change the location where Cache files are saved in the preferences menu. But the reality is you'll still need to do some periodic housecleaning on the system to deal with them.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
