Exporting .srt sidecar file? (Or workaround)
Ethan Roberts
on Aug 11, 2016 at 6:57:49 pm
Hey all - I have a question about exporting .srt files from Premiere Pro CC.
My place of work captures captions via an AJA io 4K. Those end up as .scc files, which we then drop over the corresponding QuickTime video files in Premiere. I'm looking for a way to export those captions as .srt files. When I go to File > Export and look under the Captions tab in the Export Settings window, the only Sidecar File formats I can select from are .scc, .mcc, .xml, and .stl. However, Adobe's "Premiere Pro Help / Working with Captions" page (https://helpx.adobe.com/premiere-pro/using/working-with-captions.html) states that "You can also export closed caption data to an open caption file (SRT file format)."
Am I missing something? Is it possible to export caption files as .SRTs in Premiere? If not, does anyone know of a good third-party workaround for this problem? My supervisor has tried a few different open-source programs, but since we're a Mac-based operation, most of the ones he tired are a little buggy. Any insight is appreciated!
Ethan Roberts
Master Control Operations Specialist
Austin Community College
Highland Business Center
Alex Udell
Re: Exporting .srt sidecar file? (Or workaround)
on Aug 12, 2016 at 3:06:22 pm
Mabe 2 step
thru XML
then XML to SRT?
see this page:
http://www.videohelp.com/software/Subtitle-Edit
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Jim Cunningham
on Aug 14, 2016 at 12:32:47 pm
I can confirm that Adobe claims to output srt:
"You can also export closed caption data to an open caption file (SRT file format):" but I could not find a way to do it either.
I also saw some scc converters, but they seemed to be PC based. I'll keep looking, and if I find something will report back.
Admittedly, I am just starting to play w/ captioning an am most curious as to why you need srt? I believe Youtube and seemingly may other systems will take (mux) a scc file. How do you plan to use the srt?
Jim
