Favorite Effects Bin/Commonly Used Effects Section
David Smooth
on Aug 9, 2016 at 2:18:24 am
I do a lot of repetitive editing work which require a lot of the same effects, video and audio, across my clips.
Is there a way to pin or put commonly used effects into a section/bin on its own rather than have to scan through all the folders every time you need to drop an effect on a clip?
Thanks in advance,
Dave
Ann Bens
Re: Favorite Effects Bin/Commonly Used Effects Section
on Aug 9, 2016 at 10:19:01 am
Make a custom bin.
Way at the bottom of the effects window.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Joe Barta IV
on Aug 9, 2016 at 1:50:42 pm
You can Right Click on the effect in the Effects Control tab and select Save Preset... Then it will appear in the Presets Bin of the Effects tab.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelife
http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
