Missing Overlays?
Gabriel Regalbuto
Missing Overlays?
on Aug 2, 2016 at 7:41:38 pm
The recent update has disappeared my timecode overlays. No matter what settings I tick I can't get them back in the program monitor. Still working in the source viewer, oddly enough.
Anyone else have this problem or any suggestions on remedies? It is really a headache not to have that info handy.
Mike Kaus
Re: Missing Overlays?
on Aug 4, 2016 at 11:13:42 pm
Having the same issue. They work for a few seconds after start up, then disappear.
Jos Driessen
on Aug 13, 2016 at 3:53:29 pm
I contacted Adobe about this issue and they let me use my setting from last version by changing the names of the 10.0 and 9.0 folders, and it did the job. For a while. Now I have the same issue again. Hello there at Adobe, help us...
Colin Hazard
on Aug 19, 2016 at 3:06:14 pm
I'm having the same issue. I've found that toggling the "Toggle Multi-Camera View (Shift 0)" button on and off will fix the problem. At least temporarily.
Adam Dunlop
on Oct 25, 2016 at 9:36:38 am
Worked for me. Had a feeling it was tied up with the multi-cam.
Lorrin Braddick
on Dec 6, 2016 at 11:32:30 am
Having the same problem... am not using multicam, and toggling it isn't making a difference.
Anyone found any other workarounds? really frustrating.
L
"Those aren't pillows!!!"
Kevin Carlson
on Jan 27, 2017 at 9:19:07 pm
Same problem here--super annoying.
I'm not using multi-cam either.
Sometimes closing and re-opening the program mon. panel has worked.
Dan Powers
on Jan 30, 2017 at 5:01:25 pm
Press SHIFT & 0 (zero) Two times and it will come back on. Think of it as a temporary bug reset button.
