Problem rendering simple shape on top of still image / frame hold clip
Ben Hudnut
on Jul 29, 2016 at 7:22:21 pm
Trying to draw a circle on top of a still frame clip – to call attention to that part of the image.
I made the clip of the still image using "Insert Frame Hold Segment."
I made the circle using "Circle" in "Generate" in "Video Effects."
It looks fine in the sequence playback, but when I render it, the circle gets fuzzy / distorted / messed up.
1080i footage. Wonder if it has something to do with how PP frame-holds a single frame of that.
Thanks for any ideas!
Alan Lloyd
Re: Problem rendering simple shape on top of still image / frame hold clip
on Jul 31, 2016 at 1:17:49 am
What you're seeing is a field rather than a frame.
1080i was the key.
