Mixing 4k video with 1080p and keeping them both Full screen
Tim Applegate
on Jul 27, 2016 at 3:11:22 pm
If I start with a 4k file and blend in a 1080 file, the 1080 portion is considerably smaller due to the resolution. If I start with a 1080p file and blend in the 4k file the 1080 starts in full screen and zooms in on the 4k file with an extreme "crop."
Any suggestions to being able to blend both resolutions with out zooming or reducing the screen size 1080 file
Jon Doughtie
Re: Mixing 4k video with 1080p and keeping them both Full screen
on Jul 27, 2016 at 5:38:47 pm
Tim, they are different resolutions. You wil either have to scale up the 1080 footage or scale down the 4K footage.
What is your final output going to be? That will help you decide.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Tim Applegate
on Jul 27, 2016 at 6:10:11 pm
I understand that part. I was under the impression Premier would automatically scale the video to the project size.
Daniel Waldron
on Jul 27, 2016 at 7:32:46 pm
Select "Default Scale to Frame Size" in your Premiere preferences.
Tim Applegate
on Jul 28, 2016 at 5:25:06 pm
Thank You
That seemed to do the trick
