Low quality title text
Ali Abdoli
on Jul 23, 2016 at 6:30:29 pm
Hi
I just started a new project that containing several title text . Soon enough i found out that the texts had really low quality . Don't get me wrong It's not blurry .
In my former projects i used to set the text size on about 50 but in this project i have to set the size on 120 to get the same size.
By the way the text is low quality both before and after exporting
Gary Huff
Re: Low quality title text
on Jul 24, 2016 at 7:04:18 pm
[Ali Abdoli] "Soon enough i found out that the texts had really low quality . Don't get me wrong It's not blurry ."
Ali, what is your sequence setting? A UHD setting would require a larger font size than HD. And what do you mean by "low quality"? Is it heavily aliased? And is this after you render the video or when you are watching playback on your Monitor window? If you have a UHD sequence and you have it set to not display at full resolution, that would make your test look poor, but the render should be fine.
