Is it possible to capture 4k from program monitor in realtime?
YoungBu Kwon
on Jul 21, 2016 at 2:22:52 am
The components that I consider are
premiere pro
OCZ SSD PCI-E 1TB for realtime playback
much above minimum required video card
Decklink 4k extreme (blackmagic)
HyperDeck (blackmagic)
I am thinking vcr like system, so that I could capture from program monitor in realtime without rendering.
Before it goes, I don't even know premiere can actually output 4k signal to decklink output.
I would accept any comment.
Thank you.
Tero Ahlfors
Re: Is it possible to capture 4k from program monitor in realtime?
on Jul 21, 2016 at 10:47:10 am
[YoungBu Kwon] "I am thinking vcr like system, so that I could capture from program monitor in realtime without rendering."
If your system can play your sequence back without rendering then you should be able to capture the signal with another capture device.
[YoungBu Kwon] "I don't even know premiere can actually output 4k signal to decklink output. "
It's not about Premiere. You need to set up your sequence to what the Decklink supports.
