Adding blank spaces between edit segments
Eric Merklein
on Jul 20, 2016 at 5:52:16 pm
Greetings.
Is there a way to add blank space between 2 edits? In Avid there is a pull-down called Filler that you can select, and it behaves like a source. I've looked all over the place and can't see how to do this in Premiere Pro.
Thanks much.
Eric
Many thanks.
Jon Doughtie
Re: Adding blank spaces between edit segments
on Jul 20, 2016 at 8:52:33 pm
I treat the entire sequence as "filler". For example, if I want to ripple everything downstream two seconds from the blank space I am creating, I lasso all of it, then type "+129" (29.97 timeline) or "+159" (59.94 timeline) on the keypad, and press enter.
This opens a two second gap that plays as black, and ripples everything to the right of it, maintaining the clips relationships relative to each other.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Alex Udell
on Jul 21, 2016 at 11:49:15 am
Hey Eric....
if you need a filler object....as sometimes this is easier to reuse as an insert edit object...
create a transparent video clip or black color matte...
those should do the trick....
hth,
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Eric Merklein
on Jul 21, 2016 at 1:30:57 pm
thank you for getting back to me Alex. I did create a clear title and that did the trick, but was hoping to have a way to push my timeline down without adding a real edit.
Hopefully an update will let us add space just by marking in /out then insert empty space.
Best,
E
Many thanks.
Alex Udell
on Jul 21, 2016 at 7:29:43 pm
in that case...
just do what Jon said.
Alex Udell
Eric Merklein
on Jul 21, 2016 at 8:13:09 pm
Already did. Thanks again.
E
Many thanks.
