C300 MKII Editing workflow.
Ben Lewis
on Jul 18, 2016 at 5:02:35 pm
Hi all,
I'm looking for an efficient workflow for editing 4k footage shot on C300 MKII. The footage specs are as follows...
Video:
4K 4096 x 2160 (1.0)
24fps
XAVC
Captured at
10-bit 4:2:2
410Mbps
Audio:
24-bit-4 Channel mapped to 4 Mono.
My machine is...
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
AMD Radeon R9 M395X 4096 MB
I am aware of the fact the drives Im running from are only 5200rpm connected via usb3.
I do have a 1TB LaCie d2 Quadra Hard Disk eSATA 3Gbits USB Firewire 400 & 800 but I'm not sure if that drive is 7200rpm and I would have to invest in either a thunderbolt to firewire 800 adapter or USB 3 to esata.
I've considering transcoding the content to something like prores hq but not sure if this will smooth playback in premiere.
I don't have budget for new drives so ideally want to use my existing ones.
Any suggestions for best editing workflows in this format would be greatly appreciated.
Ben
Gary Huff
Re: C300 MKII Editing workflow.
on Jul 18, 2016 at 11:53:09 pm
Was the proxy functionality of the C300 Mark II used? I use this all the time, edit from the proxies, then reconnect to the material at the end.
Only time I do not use proxies is for the 10-bit 4:2:2 modes (50 and 160Mbps flavors).
Ben Lewis
on Jul 19, 2016 at 6:29:06 am
Hi Gary,
Thanks for getting back to me. No, we didn't use this feature. We shot at 10 bit 4:2:2 but the bit rate was 410 Mbps I believe.
Is the proxy feature where you can record onto sd cards?
I've been checking the footage in premier and noticed some lag but I now think this may be the fact I'm running from a usb 3 - 5200rpm drive.
One thing both my DOP and I found interesting is the fact you have to change the cameras system frequency to be able to shoot at 24fps.
Gary Huff
on Jul 19, 2016 at 10:02:06 pm
[Ben Lewis] "Is the proxy feature where you can record onto sd cards? "
Yes, it records low bitrate 8-bit 4:2:0 footage for you to edit with.
Randy Larcombe
on Jun 22, 2017 at 12:31:25 pm
Hi, How do you edit with the proxies and the relink to the hi res files? The proxy files have a P after them which stops the files from relinking at least in Resolve anyway.
Ben Lewis
on Jun 22, 2017 at 12:56:13 pm
Hi, what software are you using to edit? What drives are you using and how are they connected?
