How to avoid scaling twice after rotation?
Peter Wu
on Jul 18, 2016 at 4:10:54 am
I have to rotate a video by 1.1 degree because it is not level. Then I zoom in to 103% to crop out the black corners.
The source is HD 1920 x 1080 and the output encoded video is 1536 x 864.
This results in the video being scaled twice, first from 1920 x 1080 to 103%, then to 1536 x 864 during encoding.
Is there a way to make only one scaling operation to reduce the blur introduced by scaling?
I'm using premiere cs4.
Alan Lloyd
Re: How to avoid scaling twice after rotation?
on Jul 18, 2016 at 5:24:01 pm
Export the rotated and slightly up-resed clip to something comparatively "lossless" and use that.
Lagarith or CineForm, maybe, at a good high bitrate, and possibly (depending on the content) a touch of sharpening applied should help.
And yes, as Dave comments, your export dimensions seem somewhat unusual. What's the output headed for?
Peter Wu
on Jul 18, 2016 at 6:03:28 pm
It's for youtube. I don't want to upload the full 1920x1080 for several reasons:
- I want a smaller file size than HD so the upload go faster
- after rotation, the video no longer has 1920 x 1080 effective resolution so why waste the file size and give false expectation to audience
1280x720 is probably a more common resolution, but is a little too low so I pick something in the middle. Is there a better choice?
Alan Lloyd
on Jul 18, 2016 at 8:06:07 pm
Does YouTube even have a 1536 x 864 setting? (I have not seen one.)
Tero Ahlfors
on Jul 18, 2016 at 8:12:57 pm
Just use standard resolutions like 720p. You're not gaining anything from that weird resolution.
