Audio is low when importing footage from another sequence!
Daniel Thomas
on Jul 17, 2016 at 2:58:30 am
Hi, I make videos on YouTube and I have an 'outro page' which has audio for the duration of the outro page (About 15-20 seconds). In Premiere Pro I have the outro page sequence, and the final video sequence, to which I import the outro page into when I am almost finished editing the final video.
The problem I am having is when I import the outro page sequence (drag & drop, not file> import...etc) into the final video sequence, the outro audio is significantly lower than when it was in it's own sequence. If that makes sense?
If it doesn't, then this image might help explain. (Please note, that I'm in the middle of editing this video, so that's why it looks a bit weird).
The sequence on the left is the outro, and the sequence on the right is the final video. When I drag & drop the entire outro sequence from the left sequence, into the right, the audio volume drops significantly. The volume settings are the same for both sequences, but the volume is still lowered than when it was in the outro sequence.
If anyone can assist me with this, then i'd be very grateful. Thanks in advance :)
- Dan
