Using PAL MPEG-2 in NTSC Project
Drew Angle
on Jul 11, 2016 at 10:17:35 pm
Hey!
I'm editing a documentary in Premiere. I acquired some files from one of the subjects. They seem to be DVD rips that are PAL.
Specs:
MPEG-2 Video, AC3, 48000Hz
The file plays fine in QT and VLC. When I try and convert this file to anything else the audio is always out of sync.
Suggestions?
Ann Bens
Re: Using PAL MPEG-2 in NTSC Project
on Jul 11, 2016 at 10:45:46 pm
Ask for the original disk.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Drew Angle
on Jul 12, 2016 at 4:53:30 pm
I can look into this. What would be the benefit of having the original PAL-DVD over the file I currently have?
Drew Angle
on Jul 12, 2016 at 5:17:13 pm
So here's one fix that seemed to be working and I'm curious what the thoughts on this approach are:
In Adobe Premiere I select the PAL clip in its bin, right click and choose to "Interpret Footage" – I then change the frame rate from 25.000 to 23.976 (the base frame rate for my project).
If I drag this clip to the timeline and advance the audio by 12 frames it seems to play in sync.
