Edit clip in Adobe Audition grayed out
Duke Sweden
on Jul 8, 2016 at 11:24:12 pm
OK, at the risk of appearing to try and take the #1 spot from Walter Biscardi I'm putting up another post because my bug thread no longer seems to attract any responses.
When I right click on any type of audio clip, i.e. original, post-Plural Eyes'd, etc. "Edit clip in Adobe Audition" is grayed out. Worked fine in the previous versions. Whattup? Anyone else?
Chris Wright
Re: Edit clip in Adobe Audition grayed out
on Jul 9, 2016 at 12:56:27 pm
https://forums.adobe.com/thread/2163285
Duke Sweden
on Jul 9, 2016 at 2:31:14 pm
No, that isn't the problem. But I found out that, instead of right clicking the audio track, if I go by "Edit" on the menu bar, then it's not grayed out. BUT, it then gives the choice of editing the entire sequence or just one clip, but clip is now grayed out. You have to edit the entire sequence. BUT, when you click on sequence, a dialog window opens with some more options, and when you click ok, the window closes but Audition STILL doesn't open.
I tried opening Audition first, that didn't work, but somehow I finally got a file to open in it, but there were 5 different files, not just the audio track I wanted to work on. Then, on the effects rack, there was no "Apply" button, then suddenly it appeared. I'm thinking that because you can send out files to AME to render, and it now includes a video window, using Audition is a whole new ballgame. I'll check the Adobe tutorials. Or maybe just go back to cc 2015. This is all too complicated for what I do.
christina rule
on Oct 6, 2016 at 4:32:00 pm
Did you ever figure this out? I am having the same issue.
http://www.christinarule.com
Duke Sweden
on Oct 6, 2016 at 6:54:24 pm
What I ended up doing was re-installing the previous version of Audition. Normally the latest upgrades aren't backward compatible but in this case it worked. I can live without going straight from Audition to Media Encoder. Hope that helps.
Yuri Martins
on Nov 18, 2016 at 8:35:34 pm
In order to fix it you just have to update the sesx registry key
HKEY_CLASSES_ROOT\.sesx to AdobeAudition10_sesx
1) Winkey+R, type regedit
2) search for the path HKEY_CLASSES_ROOT\.sesx
3) double click on (Default)
4) type AdobeAudition10_sesx
5) hit Ok, open Premiere again and done
Duke Sweden
on Nov 18, 2016 at 9:43:18 pm
I decided to upgrade to CC 2017. I installed Audition first, then Premiere Pro. All works fine.
Duke Sweden
on Nov 20, 2016 at 11:37:52 am
And, of course, after finally uninstalling Audition 2015, Premiere Pro now has Edit in Audition grayed out, even though it was opening the latest Audition with no problem before I uninstalled. Editing the registry as you suggested does nothing.
Duke Sweden
on Nov 20, 2016 at 12:17:31 pm
Well, I tried the other trick of assigning Audition 10 as the default program for .sesx files. No good. Then I uninstalled Premiere Pro and re-installed. Still nothing. How can it be that the only way I can get it to work is to have Audition 8 installed on my PC? Friggin' Adobe....
Duke Sweden
on Nov 20, 2016 at 12:34:32 pm
I re-installed cc 2015 and sure enough, Edit in Audition is no longer grayed out. However, it opens cc 2015, not cc 2017, even though the registry is set for Audition10. Why did I wake up at 3:30 this morning!!!
Duke Sweden
on Nov 20, 2016 at 1:26:29 pm
OK, my final solution was to remove both Auditions and Premiere Pro, then re-install first Audition CC2017, then Premiere Pro CC2017. Now I can "edit in audition" again.
Now, another question. How do I access "Assign Mix Type"? It's always, uh, grayed out!!!
Mike Vasconcellos
on Nov 26, 2016 at 2:38:04 am
Yuri's registry entry change worked for me to fix the greyed out "Edit in Adobe Audition" issue in Premiere.
Duke Sweden
on Nov 26, 2016 at 3:06:11 am
Not me. As I said, had to uninstall and re-install Audition first, then Premiere Pro. Just another solution in case the others don't work for ya.
Patrick Haley
on Feb 25, 2019 at 8:49:51 pm
In case anyone searches this in the future, I had this issue and this is what I did. I don't normally use Audition, so I didn't have it installed. After installing and playing around in the program, I went to edit the Premier Pro clip in Audition, but it was greyed out. I saved the file, quit and relaunched Premier Pro, and it worked fine. Just make sure that the audio clip is in a sequence first.
