Shift A equivalent
Steve Cohen
Shift A equivalent
on Jul 4, 2016 at 7:16:16 pm
I'm making the switch from FCP 7 to Adobe CC and I'm picking it up pretty quickly.
There are some things that I find really useful in FCP and just can't figure out how to do in Premier.
The one I'm battling now is marking the in and out points of a clip in the timeline.
FCP is Shift +A.
I can't figure it out for Premier. Even if I switch to the FCP 7 keyboard layout it doesn't work.
Is this one of those things that just won't happen like Insert with default transition.
Steve
Steve Cohen
Ann Bens
Re: Shift A equivalent
on Jul 4, 2016 at 8:22:53 pm
Select clip and hit / ?
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Steve Cohen
on Jul 4, 2016 at 9:13:56 pm
Thank you Ann.
That's helpful.
Steve Cohen
Alex Hawkins
on Jul 5, 2016 at 11:11:23 pm
Also Steve there are quite a few actions within PPro that don't have a default keyboard shortcut attached to them. If you're using the FCP7 layout then Trim & Ripple Trim next and previous edits to playhead would be the first ones I'd map to shortcuts.
Cheers.
Alex Hawkins
Canberra, Australia
Steven Cohen
on Jul 5, 2016 at 11:55:56 pm
Thank you Alex, but I'm using the standard keyboard layout.
I want to be a Premiere editor, not a Final Cut Pro editor working on Premier.
Steve.
Andrew Kimery
on Jul 6, 2016 at 12:22:12 am
[Steven Cohen] "I want to be a Premiere editor, not a Final Cut Pro editor working on Premier."
From what I recall PPro's default layout is pretty barren. It's been a while since I used it though so maybe it's gotten better. Don't be afraid to create your own custom keyboard though, it's why that feature is there. ;)
Steven Cohen
on Jul 6, 2016 at 12:28:15 am
I am as I find things I need.
Steve.
David Roth Weiss
on Jul 11, 2016 at 3:18:55 pm
Get yourself a Premiere keyboard.
David Roth Weiss
Director/Editor/Colorist & Workflow Consultant
David Weiss Productions
Los Angeles
David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
