Exporting Apple ProRes 422 from Premiere in Windows.
Juan Manuel Palomino Domínguez
on Jul 1, 2016 at 6:33:24 pm
Hi. I need to export a video with these settings:
Apple ProRes 422 (HQ)
ITU-R BT.709 color space
VBR expected ~220 Mbps
1920 x 1080 square pixel
Original Aspect Ratio
Áudio 5.1
Channels: L, R, C, LFE, Ls, Rs
AIFF or .WAV uncompressed
LPCM ou Big Endian ou Little Endian, 16-bit ou 24-bit, at least 48kHz with 128 Kbps in any one
Áudio 2.0 Stereo
Channels: L e R Stereo, não pode ser DUAL MONO.
Arquivo: .AIFF o .WAV uncompressed
Any kind of help would be really apreciated. Thank you!
D j Harris
Re: Exporting Apple ProRes 422 from Premiere in Windows.
on Jul 28, 2017 at 1:53:19 pm
Hi Juan,
Had this request from a client a while back and was recommended either this:
http://www.cinemartin.com/cinec/
or this:
http://www.acrovid.com/download.htm
In the end the client didn't need pro-res, but I tested FootageStudio 4k and it seemed to produce good results from a hi-res export through Adobe Media Encoder (I think I did Cineform 10 bit, or maybe DNXHD from Adobe) then compressed that in FootageStudio 4k. I don't know off the top of my head if it will do the audio formats you need but it's worth a shot.
(I think there is also a way of doing it for free with FFmpeg but I didn't test that)
Hope that's of some help.
Dan
