removing side black bars from a vertically oriented video
David Palmieri
on Jun 29, 2016 at 3:02:26 am
I created a video in premiere cs6.
it is basically a vertical video with black bars on the sides from cropping that i did.
i do not want to save the black bars. i just want to save the vertical video piece.
is this possible?
i tried to see if i could change the sequence settings but everything was deselected and unchangeable.
Paul Neumann
Re: removing side black bars from a vertically oriented video
on Jun 29, 2016 at 3:35:56 pm
Very first field on the Sequence Settings screen is "Editing Mode". Set this custom and then set whatever output dimensions you want.
David Palmieri
on Jun 29, 2016 at 4:48:43 pm
can you be more specific as to what you mean about codec and media container?
thanks
because for some reason as i have it now, when i type in custom project settings of 810 pixel horiz by 1080 pixels vertical, it is making a square frame. which makes no sense to me.
Ann Bens
on Jun 29, 2016 at 8:11:05 pm
If you want to make a vertical video out of a landscape timeline you also need to crop the video in the source tab of the export settings.
What are your seqeunce settings, clip propeties and export settings, and Post a screenshot of the program window.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
