Change full screen playback ratio
Alistair Stewart
on Jun 28, 2016 at 2:17:17 pm
Hello!
I'm editing a 1080 video in a 1080 timeline but I am currently playing around with aspect ratios. I've added some widescreen bars using a png file on the timeline.
I'm currently using an LG Ultrawide monitor and am curious to know if there's a way to change the full screen playback so I wouldn't see the black bars so the video would fill the screen.
I've tried editing in a 1080x822 timeline for the effect but the footage seems to lose resolution this way.
Any ideas if it's possible?
Dave LaRonde
Re: Change full screen playback ratio
on Jun 28, 2016 at 4:33:51 pm
Well, you're going to lose resolution one way or another if you shoot 1080 video. There's no way around it. You can't invent what isn't there. You need to shoot higher-resolution video so you work in a timeline resolution that works with the wide monitor, then scale & position the high-resolution video to frame it properly for the wide monitor.
Incidentally, how do you plan to play back this super-wide video on normal HD monitors? Or is this just something you'll play for your own enjoyment?
Dave LaRonde
Promotion Producer
