Can't key out background in DNxHD files?
Duke Sweden
on Jun 21, 2016 at 7:52:43 pm
I can't remember if I could do this before. I converted my latest batch of green screen .MOV files before I did anything to them. When I import the .mxf files into Premiere Pro, when I apply Ultra Key OR Primatte Keyer, the green portion turns black, not transparent. Like I said, I don't remember if this was how it behaved before. Should I be able to key out backgrounds in .mxf format?
Alan Lloyd
Re: Can't key out background in DNxHD files?
on Jun 22, 2016 at 5:50:50 pm
Just to clarify, have you put the clip over a BG and then keyed out the green?
Jon Doughtie
on Jun 22, 2016 at 7:16:29 pm
Nothing underneath it? If that is the case, black is what you would see.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Duke Sweden
on Jun 22, 2016 at 7:28:08 pm
Yes, of course I have a background underneath. I'm not getting a solid black, the green background is turning black. I can still see the folds and all. It's literally like taking the green muslin sheet and dying it black.
Since you've both asked me that question I'm going to assume that this isn't normal behavior. I will try again and see what happens and report back. I know that sometimes Premiere Pro will start doing weird things like not allowing the audio portion of a clip to be dragged to the timeline, for example.
Duke Sweden
on Jun 22, 2016 at 7:35:07 pm
Yeah, now it works fine. Weird things, these computers ;-)
