Adobe Premiere CC 2015 too slow
Michael Alexandrovich
on Jun 21, 2016 at 3:28:23 pm
Hello,
I'm currently facing a very frustrating issue in Adobe Premiere CC 2015. I'm trying to edit 1080p, 30 fps footage with a bitrate of 20Mbps but editing it is impossible for me at the moment because Adobe Premiere is too slow.
I import the footage, and when I double click on the footage for it to show up in the "source" window, it just shows the "media pending" image/message. It takes minutes for the thumbnail to load, but even then I can't properly scroll through the video and figure out which parts I can use to put in the sequence. It only displays on frame from some part of the video and not the one at the marker that I move. Even if I cut out some arbitrary portion of the clip on put in a sequence (even though I can't tell what I'm working with), I get the "media pending" image again for the thumbnail in the "program" window. After a real thumbnail loads, I press play, but it doesn't even play the clip! The play button doesn't even always become the stop button. If I wait longer, only audio plays, but that single frame remains even though the marker runs to the right, meaning that the video should be being played. Pausing somewhere later, it takes minutes again to load a frame, a snapshot of where I paused.
System Specs:
CPU: AMD FX-6300 at 3.5 Ghz
Graphics card: AMD R9-380
RAM: 2 x 4GB DDR3 in dual channel
Storage: 1TB SSHD, 7200 RPM
I've edited videos on less powerful machines without problems, so I can't image specs being the issue.
Any ideas of how I can fix this issue? Thanks in advance!
Jacob Bond
Re: Adobe Premiere CC 2015 too slow
on Jun 21, 2016 at 6:17:42 pm
I'm having the same exact issue. And it really only started happening recently.
Specs:
Windows 10 64 Bit
4x4GB DDR4 RAM
Core i7-5820k @3.30GHZ
Nvidia GTX 560 OC
250GB SSD for Cache and Software
I am using a H.264 Codec at 1920x1080p at 60fps
My bitrate is 10 and my target is 12 at VBR 1 Pass
However coding used to only take an hour at most for my medium quality animations. Not they take several hours and on top of that MY CC suite for both Premier Pro and After Effects slowed down heavily. It takes 10-20 seconds just for a frame to load or a thumbnail to refresh.
If anyone has any idea I would appreciate the advice.
Thanks.
on Jun 21, 2016 at 6:42:18 pm
Are you using the 2015 version too? I remember Premiere 2014 working fine on a different system a while back. Maybe it's something to do with the update?
Jacob Bond
on Jun 21, 2016 at 7:33:20 pm
I am actually in CC 2014.
Jacob Bond
on Jun 21, 2016 at 8:23:01 pm
I had a windows 10 update last week, the last update before my project started and after my previous project when things were fine.
http://prntscr.com/bj9s9d
Perhaps these have something to do with the issue?
On another note does anyone happen to know why Adobe AE is running even though AME is the only Adobe Program running?
http://prntscr.com/bj9sue
Should it be running even though hectically it's not even open?
on Jun 21, 2016 at 9:24:24 pm
Now that I think about it, I've been having performance problems in CPU heavy games after installing that windows 10 update. It's quite possible that this issue has something to do with that rather than the Premiere version.
Greg Jones
on Jun 21, 2016 at 6:51:40 pm
I just bit the bullet and updated to 2015.3 and the performance is amazing. I'm playing back things that used to be choppy and now are smooth.
Greg Jones
Greg Jones
Orlando,Fl.
http://www.d7-inc.com
on Jun 21, 2016 at 7:08:40 pm
What are your system specs, if you don't mind sharing? Do you think that mine are sufficient for what I'm doing?
Greg Jones
on Jun 21, 2016 at 7:21:10 pm
2008 Mac Pro 3,1
32GB Ram
GTX680 Nvidia Graphics Card
32TB Raid
AJA Kona 3G
Greg Jones
D7,Inc.
Orlando,FL.
Daniel Fletcher
on Jun 22, 2016 at 5:57:58 pm
Hey Greg What OS are you currently running?
[Greg Jones] "2008 Mac Pro 3,1
32GB Ram
32TB Raid
AJA Kona 3G
Greg Jones
D7,Inc.
Orlando,FL."
Greg Jones
on Jun 27, 2016 at 12:21:11 pm
I'm running 10.11.5, however I found that 10.11.3 was more stable. I'm getting freezes in 10.11.5, though they are system freezes and have nothing to do with Premiere.
Greg Jones
D7,Inc.
Duke Sweden
on Jul 2, 2016 at 11:28:45 pm
Just wait... ;-)
btw, you'll see at least some improvement if you empty your cache from AE (the other apps as far as I know don't have that option in Preferences). It loads up REALLY fast, and you'll have like 252 meg or more just sitting there taking up space and slowing things down.
on Jun 26, 2016 at 5:20:15 pm
Creative Cow is the most useless forum. No one can suggest useful advice to the OP and some people just say that the issue being experience by the OP had not been experienced by them, while others just say that they're also having similar issue but haven't found a solution to it (I WONDER WHY!)
Chris Wright
on Jun 27, 2016 at 12:09:11 am
1. pref, media
Disable "Enable Accelerated Intel h.264 decoding
2. clear media cache/temp files
and AppData\Roaming\Adobe\Common\
Chris Tompkins
on Jul 2, 2016 at 9:23:35 pm
2015.2
win 7
very slow, black screen for video
freezes/lockups
Chris
