Changing Resolution In Source Monitor
Eric Nicastro
on Jun 20, 2016 at 5:57:05 pm
I'm working on a project that is 1080p. I have some footage that is 4K. When I open a 4K clip from the sequence timeline in the source monitor (not from the bin), that clip is showing at full 4K resolution in a 1080p window. So I'm only seeing the 1080 center-cut of the image, not the full image. Is there way to fix this so I can see the full frame? The clip is scaled to 50% in the timeline.
Tero Ahlfors
Re: Changing Resolution In Source Monitor
on Jun 20, 2016 at 7:07:06 pm
That shouldn't happen. Does the clip have any (master)effects on it? Is the source panel's zoom setting other than fit?
Eric Nicastro
on Jun 20, 2016 at 7:52:22 pm
The clip does not have any master effects on it. I've only applied color correction effects to the clip in the timeline. I've disabled those and even removed them completely and that doesn't make a difference. As for the source panel's zoom settings, changing it from fit to any other value makes no difference either.
Ivan Volkov
on Jun 20, 2017 at 9:13:56 am
I have the same problem. Is there any solution?
http://prntscr.com/flwx70
David Cain
on Oct 3, 2017 at 3:14:34 pm
Same issue for me. Anyone got an update on this?
http://www.davidcain.ca
